18 and 19
More codes came up, replaced piston in lower caliper, had to unhook motor connections, hooked everything back up, went to move the machine, heard a spark, and had code 19, rechecked my connections, now rev is ok, when I put it in fwd and set on the accelerator, get code 18, hope someones got info for 18 and 19
  • Posted 10 Sep 2010 05:00
  • By Barfly_olaf
  • joined 10 Oct'09 - 81 messages
  • Nova Scotia, Canada
SEMPER FIDELIS
18 - Field Driver Fault R
Fault Signal from H-Bridge board
H bridge board detected abnormal over current
19 - Field Over current R
more than 45 Amps
Right motor field over-current is 45 A or more
So which motor did you build this caliper on? Was it the right motor by chance?
maybe the caliper is hanging up and holding the motor?
Just a guess since this problem came up immediately after you built a caliper?
  • Posted 21 Apr 2014 20:25
  • Modified 21 Apr 2014 20:33 by poster
Check the field wires (red black?) from right drive motor back to the control boards -may be bad h-board or main board if harness is ok
  • Posted 21 Apr 2014 11:24
  • By troy_m
Maxlion R2D35
Manitou M50-4
Maxlion R2D35
Manitou M50-4
