152-OPC30TT / 152-88-01537
Can anyone tell me what the P/N is for the horn control module? The one I took off has a P/N 154-010-308. Raymond Parts in my area told me it changed to P/N 154-010-242. NOT!!!
  • Posted 4 Aug 2012 03:01
  • By rjjburns
  • joined 1 Jul'11 - 14 messages
  • Michigan, United States
Thanks for the info. Parts on order.
  • Posted 7 Aug 2012 22:14
  • By rjjburns
RSB 728 states that the module is no longer available and the truck has to be retro-fitted with relay and diode assy.
  • Posted 7 Aug 2012 02:03
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
Send me an e-mail (it's in my profile) and I can send you some info on your problem.
  • Posted 7 Aug 2012 00:42
  • By joe_d
That 233 is just a suppessor so it can't be the right one. I have diagrams of what's inside some of these modules and can check that out, but not until tomorrow. The 242 is just a diode connected to 2 of the terminals.
  • Posted 7 Aug 2012 00:06
Serial # correction, Should be 01837. This has 5 wires. Terminals 4&5 PC-X&Y,#2 signal from S3(horn switch), 1 Batt. neg., 6 horn neg., horn receives 24vdc batt. connected.
  • Posted 6 Aug 2012 21:25
  • Modified 6 Aug 2012 22:17 by poster
  • By rjjburns
This is mounted right next to the horn and there are 2 wires hooked to it? If so, you need a 154-010-233. Terminals 1 and 6 are used ( holding it with the contacts facing up, 1 is on the left and 6 on the right). Terminal 1 will be positive and 6 will be negitive. To test it you should get 20K-60k ohms between 1-6. Switching the test leads should get 20k-60k also.
  • Posted 4 Aug 2012 23:26
Not to be rude, if possible can you send me a diagram or testing diagram, that 242 ate the connector. Need to make sure.
  • Posted 4 Aug 2012 11:16
  • By rjjburns
I have 2 of these beauties. Plus a couple older(Clark &Yale). Out of 13 forklifts here, I have only 2 made this century.
  • Posted 4 Aug 2012 06:11
  • By rjjburns
How about 154-010-233 horn suppressor module
  • Posted 4 Aug 2012 05:07
  • Modified 4 Aug 2012 05:53 by poster
My God! I thought all the dinosaurs were dead! According to my parts guy that # did cross but now it crosses to "unavailable--see service bulletin". He's checking on it now.
  • Posted 4 Aug 2012 04:51
  • By joe_d
Enforcer FD50T-MMA
Manitou MH25-4
