10" and 15" forklift steel rim weight...help!!
Please, I need to know the weight of a 10 and 15" steel rim for forklift tire....any will do....does anybody here knows it??Please help....I need it for my project on university, thanks
  • Posted 9 May 2008 19:30
  • Discussion started by Leo27
  • Croatia, Croatia
2JDBurton>I do not own a company or drive a forklift, I'm a student,and I'm doing a vibration simulation of a forklift...if I could, I would weight it, but it's complicated....maybe I will be able to access the forklift next week, and then I will try to weight the wheels...
  • Posted 20 May 2008 05:14
  • Reply by Leo27
  • Croatia, Croatia
Not to be mean but honest, if you have a rim on the truck weigh it, if you are ordering one the seller should be able to provide a shipping weight for you.
  • Posted 19 May 2008 22:41
  • Reply by JDBurton
  • Virginia, United States
Hi Leo
The rubber tire would be included in that weight. Are you able to contact the parts department with a request for a shipping weigt?
  • Posted 19 May 2008 06:15
  • Reply by randal_s
  • Nova Scotia, Canada
Ok, that weight it just for the rim or for the whole wheel (rim + tyre)?
  • Posted 19 May 2008 06:07
  • Reply by Leo27
  • Croatia, Croatia
My e-mail is lstipisic@gmail dot com
  • Posted 17 May 2008 23:49
  • Reply by Leo27
  • Croatia, Croatia
Hi Leo
I have not worked on that Machine, but the best guess my survey came up with was around 70 pounds (31Kg) for the 10 inch rim and 100 pounds (45Kg) for the 15 inch rim.
your email will only come up if you replace the"." with dot, otherwise the email address is striped from your response.
R
  • Posted 17 May 2008 00:57
  • Reply by randal_s
Yes it helps a lot, and if you could help a litle bit more I would be grateful. Here are some info....the forklift is a internal cmobustion (diesel engine), tires are 10" - 6.50 width and 15" - 8.25 width...they are pneumatic tires. The forklift is the same as JCB TLT 30 Teletruk....does that help you? Could you give me some specific info now:)
http://www.jcb.co.uk/products/MachineProduct.aspx?PID=74&RID=13
  • Posted 16 May 2008 03:29
  • Reply by Leo27
  • Croatia, Croatia
Hi Leo
There are to many variables to give you what you are looking for. The width of the tire, the type of tire solid or pneumatic, if it is on an electric lift truck or on an internal combustion truck. Is the rim used as part of the brake system or part of the drive system.
in general a 10" (25mm) tire can weigh from 50lbs (22Kg) to 150lbs (67Kg)
a 15" (37+mm) rim can weigh from 75lb (33Kg) to 220lb (100Kg)
I hope this helps.
  • Posted 16 May 2008 00:31
  • Reply by randal_s
Nobody??:(:(
It's very important to me,and I just can not find that data anywhere....so please, if you can, give a hand...
  • Posted 14 May 2008 21:16
  • Reply by Leo27
  • Croatia, Croatia
Can anybody help me? And 10" and 15" rim weight or the whole wheel weight will do! Please!
  • Posted 12 May 2008 19:03
  • Reply by Leo27
  • Croatia, Croatia
edition #1235 - 19 June 2025
