Narrow Aisle Lift Truck Model CDD15C, 1500kg capacity
- 26 May 2011 ( #515 )
The special advantages are:
SAFETY AND PRODUCTIVITY:
  • Advanced AC control system, eliminating the motor brushes, which minimises maintenance requirements. Intelligent regenerative brake system provides strong starting power on ramp up.
  • Adjustable driving speed. 4 levels, from 3km to 10km.
  • EPS (electric power steering) system with following advantages:
    - Steering wheels are automatically reset (up to front position) when the truck is turned on.
    - Travelling speed is decreased automatically if the truck swerves, which ensures safety operation.
    - Turning angle is shown on the display.
  • Finger-tip control via joystick: driving speed (4 levels), lifting & lowering speed, opening/closing stabilizer.
  • Stabilisers (at specific lifting heights) which can work manually or automatically to enhance stability and safety when stacking cargo.
  • Applicable in double pallets function while forks are lifting up.
  • Built-in pressure relief valve protects truck from overloading.
  • Multi-function display: battery state, working hour meter, fault status, driving speed (4 levels), angel indicator of rear steering wheel, etc.
  • Low placed battery offers lower center of gravity and better stability. Battery capacity up to 400Ah.
  • Side battery with roll-out system for convenient replacement. The battery top cover provides easy access for filling the battery.
  • Damping cushion for low-noise operation.
  • Emergency power disconnect.
STRUCTURAL:
  • Compact truck with "heavy duty" construction.
  • Low center of gravity ensures stability.
  • Wide view masts with clear visibility.
  • Masts are detachable from truck frame and with good interchangeability.
  • Low step and sensitive dead-man pedal offers comfortable operation.
  • Narrower overhead guard towards front, to reduce the risk of getting "hooked" into something.
  • Availability of 360 degree steering offers smallest turning radius of 1800mm.
  • Adjustable steering wheel and arm support give driver the most comfortable feeling.
  • Drive wheel and balanced wheel are combined together to ensure stability.
SERVICE ABILITY:
  • The low voltage protection system prolongs battery life.
  • CANbus technology reduces wiring complexity and increases reliability and service friendly.
  • Improved battery plug system makes it easier to connect/disconnect the battery for charging.
Finger-tip joystick and adjustable arm support
Manual or automatic stabilizers switch
Stabilizers and Side-way battery
Mr. Chu Jiang
Vice President
Tel: +86-571-87153626, 87153634
Fax: +86-571-87153628, 87153638
Email: ruyi@mail.hz.zj.cn, sales@liftool.com
Web: www.xilin.com
Or; Click to view the RUYI ShopFront
