UN V-Series Li-Ion Battery Forklift - A Replacement for IC Forklifts
- 2 Mar 2023 ( #1117 )
V Series Li-ion Battery Forklift
Capacity 2000 to 3500 Kg
UN's V Series Lithium-ion Forklift — the Second Generation Lithium-ion Forklift with new brand design. This new forklift adopts innovative and reliable lithium battery with CATL cell technology, Italian imported ZAPI controller and full AC motors. The combination of super performance and durability makes it a perfect replacement for IC forklifts.
This new energy forklift will meet all your imaginations by its superiorities such as long working hours, high performance, zero emission, low maintenance and operation costs. This new model is proudly named “CAPTAIN”. It’s expected to dominate the future electric forklift market and lead the whole UN Forklift fleet to success like a captain.
Super Performance and High Efficiency
  • Faster speed of travelling, lifting and lowering turns to the great productivity.
  • Strong gradeability
  • Strong and enhanced structure with IC forklift type axle and mast makes it safer and more reliable for heavy duty applications.
  • Well allocated ventilation & cooling system for the motor and battery BMS system, which are suitable for persistent long working  hours conditions.
  • Indoor: This Captain forklift can replace the traditional electric forklift inside the warehouse with more comfortable operation.
    The whole vehicle can be operated alternately in -20° cold storage for 6 hours and parked in the cold storage for 12 hours without any failure and can continue to work.
  • Outdoor(all weather & rough area) : This Captain forklift is considered as a perfect replacement of IC forklift with its super performance, strengthened structure, high ground clearance, IP54 waterproof and dustproof.
  • More convenient—Multi-shifts design: This Captain forklift adopts the side-swapping of battery pack function, which can easily replace the battery pack in a few minutes and save time.
Comfort and Ergonomics
  • Wider operation space, 50% larger operation space than traditional electric forklift, which is same large space as the IC forklift.
  • Wide view mast provides operators with super visibility
  • Advanced and scientifically layout dashboard: The LED screen faces towards the operator at a comfortable angle.
  • USB power supply design, more convenient for mobile devices charging
  • Specially molded boarding pedal
Safe and Easy Maintenance
  • Internal components are protected with fully-sealed hood, and equipped with IP54 waterproof and dustproof.
  • ZAPI controller equipped with large true-color LED screen brings excellent visibility and more clear reading; The Can-bus helps operators monitor the forklift all the time.
  • Integrated BMS continually monitors battery system and ensures safe operation.
    BMS provides protection of:
    • Overcharge
    • Overdischarge
    • Overtemperature
    • Overcurrent
    • Short circuit
  • Maintenance-free for lithium-ion battery, and side-swapping of battery pack for easy battery replacement.
  • Big open angle of the hood supports a better access to main parts.
  • Brake fluid within reach, easy to check and refill
  • Anti-slip function on hill and optional OPS function will make the operation safer.
  • In addition, the low gravity center of forklifts reduces the tipping risks.
Advantages of Lithium-Battery Technology
  • Maintenance-free with no odour from gases or battery acidification
  • Longer service life and lower maintenance compared with lead-acid  batteries
  • Charging can be interrupted at anytime
  • Fully charged in about two hours, and can be charged to 80% in 1.5 hours
  • 5-year battery warranty, about 4000 times long life cycle
For more information, please contact us!
Zhejiang UN Forklift Co., Ltd
Tel: +86 571- 86888355
Fax: +86 571-86888399
Web: www.unforklift.com
Email: get in contact
Get in touch with Zhejiang UN Forklift Co., Ltd
+ 86-57... Show
No.1, Road One,
Xindeng New District,
Fuyang, Hangzhou, Zhejiang 311404,
China
