Bolzoni Auramo: Green fingers for your flowers and plants handling
- 14 Jan 2021 ( #1008 )
Potted plants handling with fork positioner, or transported on a wooden pallet.
In the next months, the coming spring will enormously increase the handling operations in all nurseries and garden centers.
Cultivation of flowers and plants needs many kinds of manipulation and transportation of products, during the working process, from sowing, pricking-out, potting-up, and planting of flowers, plants and planting products.
At the end of the process handling of goods is needed to store, to transport, to load and unload of vehicles.
Bolzoni Auramo is able to fulfil the different need of material handling with a variety of products available in the range.
The right clamp for your planting material
To empty containers of waste material or to handle seeds bins. Here the KG-H fork clamp fitted with drum slip-on arms and the CG-S invert-a-bin holding the container on top.
To safely handle potted plants, limiting all risk of damage of dropping the valuable load, the most useful attachment is the fork clamp, in our Silver Line range, model LC-H. This unit is extremely robust and fit for hard application in the yard and in any weather condition.
The heavy pot can be gently clamped between the forks, lift and transported from the cultivation area to the store or to the lorry.
The same clamp can be used to handle and transport standard wooden pallet loaded with flowers, empty pots, bags of soils, fertilizer, seeds and other planting materials.
A 360-degree rotating version of the fork clamp, the Bolzoni Auramo KG-H model, can add other functions to the forklift. Rotating fork clamp can be useful to empty containers of waste material as well as of seeds or different kinds of grains.
In order to rotate bins with open feet, the Bolzoni Auramo Invert-A-Bin model CG-S can help doing the work. The 360-deg rotating device will allow to completely and easily emptying the bins, the top hydraulic arm keeping the bin in steady and safe position during the operation. When the top arm is not used can be moved in an upper folded position and the forklift can be used with the standard forks to handle any kind of load.
Save time reducing the number of lift truck journeys
To reach palletized goods on second deep position or to handle two pallets at a time, reducing the number of lift truck journeys.
When the lorry is coming, you may need to load the goods quickly and safely. Bolzoni Auramo reach forks models RD and RS can help increasing the productivity during these operations. The RD models can be used to handle double pallets in deep to speed up the loading activity, the RS models, thanks to the pallet stop on the moving forks, can push the pallet in second deep position, also in double deep rack warehouse. The perfect synchronized movement of the two forks assure a safe handling of the load.
Ergonomic conditions for the operator's comfort
To keep the load material at the correct height, the 1E lift table is the perfect working station.<br />At an Italian import and export garden center, loading and unloading of vehicles by pedestrian truck, here the 1S Series Lift Table.
To keep the load at the right height, in all kind of applications, this is the way operators work in ergonomic conditions. Bolzoni Auramo can also support all flowers potting operations as well as all flowers care activity thanks to the lift table range for working station, models 1E and low profile in the new Green Line range.
For a lower impact on the environment, Bolzoni lift tables are available on request with biodegradable hydraulic oil, and are all provided with high efficiency electric motors IE3. Lift tables are painted with water based nontoxic solvent free paint.
For more information on nursery plant handling solutions, please visit our website www.bolzonigroup.com and contact us by email, or contact the nearest BOLZONI AURAMO and MEYER representative.
____________________________________
Bolzoni Auramo is a Bolzoni Group brand.
Bolzoni SpA (Group HQ)
+39 052... Show
Via I Maggio, 103
I-29027 Casoni di Podenzano,
PC, Italy
