Cascade to Exhibit at Logimat 2015
- 29 Jan 2015 ( #703 )
Cascade, the global leader in providing material handling solutions, including sophisticated forklift attachments and custom forks, will exhibit at Logimat 2015 in Stuttgart, Germany.
Cascade will be featuring their White Goods Clamp, WG series with VFC (Volumetric Force Control), an intelligent combination of electronic systems and hydraulic mechanisms paired with unrivalled Cascade design and structure. The Volumetric Force Control (VFC) automatically adjusts clamping pressure based on the volume of the load. This product is designed to reduce damage caused by excessive force applied to the load when manually controlling the pressure. The VFC calculates the size of load and will clamp with the right amount of force. Force distribution is also ensured by the patented three-finger arm design, the six adjustment points on each arm, the Cascade proprietary Adjusta-Block system and the extended height arm. The White Goods Clamp with VFC is designed to maximize efficiency and speed as well as to protect the load of packed products (including the profiled arm corner casting to eliminate corner pinching damage).
Cascade will also exhibit the G-Series Sliding Arm Clamp. This model can be equipped with arms for bales or forks. The model with arms features arm corner casting to provide superior strength over the life of the clamp, a hardened full width wear strip to protect the frame from damage when scraping on the ground, full width lip over UHMW bearings to provide maximum resistance and bearing support and the hydraulic circuit is protected but easily accessible for servicing.
Cascade Push/Pulls allow to ship, receive and warehouse unit loads on inexpensive slip sheets rather than pallets.
Cascade offers a wide range of Fork Positioners and Rotators. Ask about the innovative K-Series with Fork Positioner Conversion Kit that transforms Sideshifters into Fork Positioners with just nine bolts.
Cascade will also display standard and custom forks with DAGS Magnetic Fork Covers. These fork covers can be installed and removed in seconds making them the ideal option to protect and help stabilize slippery or awkward loads.
Cascade's highly skilled sales people can recommend a customizable material handling solution based on your needs, including rental and remanufactured alternatives. To schedule an appointment with the Cascade team, or to receive complimentary tickets to the exhibition, visit http://connect.cascorp.com/logimat2015. If you cannot attend the show, visit www.cascorp.com for more information about Cascade, the new PERFORMANCE two-year warranty, or for information about Cascade products and services.
Cascade Corporation, established in Portland (OR) in 1943 and with subsidiaries in Germany and around the world, is the global leader in the design, manufacture and marketing of materials handling attachments, forks, accessories and related technologies. Their unmatched service, support and expertise, along with advanced damage reduction technology, flexible manufacturing, short lead times and quality products, positions them at the forefront of the material handling industry.
Cascade Corporation
Portland, Oregon
1-800-CASCADE (227-2233)
Send Cascade an email
www.cascorp.com
For more company and product information visit the Cascade ShopFront
1 800-... Show
Corporate Office
2201 NE 201st Ave,
Fairview, OR 97024
U.S.A
