Complete solution to guarantee absolutely flat warehouse floors
- 19 Nov 2015 ( #745 )
At Alphaplan we understand that, in the VNA sector, productivity is everything. In order to achieve maximum productivity levels, forklift trucks need to operate at their maximum speed, and in order to run at their maximum speed they need to operate on an ultraflat floor. This is where Alphaplan can help.
FloorShaver by Alphaplan utilizes the most advanced grinding technology in the world to produce the worlds flattest floors. FloorShaver is an electrically powered, fully automated grinding system which incorporates an integrated profiler graph ensuring that at all times FloorShaver is scanning the floor to assess exactly what is needed to achieve the flattest floor possible. The electrical and waste management umbilical cord allows constant floor grinding in order to provide a non-stop clean efficient system. This ensures that the floor is ground in the shortest timeframe possible, which keeps downtime and the associated costs to a minimum
Our machines are extremely environmentally friendly. The waste management system pumps the waste product through a press which separates the waste slurry from the water. It then compresses the slurry and recycles the clean water. Any excess water is so clean that it can be poured into the normal drainage systems for disposal. This reduces the amount of skips needed on site and reduces the impact on the environment. FloorShaver is also a very clean service. Due to the FloorShaver's technology we can grind your floor absolutely dust free ensuring that operations in your workplace can continue unaffected
FloorShaver is an extremely reliable, safe, flexible and compact machine. Thanks to the technology of this unique equipment, you are able to continue with the normal activities in your warehouse without interruption while the FloorShaver carries out its work.
FloorShaver is extremely efficient and can grind up to 200 meters each day again significantly reducing the disruption to operations. The machine is calibrated to the exact specifications of your companies aisles before it leaves our premises ensuring that when it arrives it can begin grinding immediately and can perform at its optimum level.
FloorShaver has the experience, expertise and technology to achieve the floor flatness tolerances required by todays warehouse MHE. We are so confident in this, that we also offer Unmatched warrantees. FloorShaver has been providing solutions the flooring needs of some of the biggest organizations in the world for over twenty years. Our website contains many references.
FloorShaver, leading the way in ultraflat floors.
Please contact:
Hans Voet- Alphaplan
t:+32 16680680
e: send an email
w: www.floorshaver.com
