yale MPE
complaint no high speed. display shows botton and wiring good.Swapped out steering motor , yes palletjack with power steering. swapped out complete head assy, steer gear handle ect. No codes. wiring and trouble shooting in book not good. Only show that this is caused by bad proximity sensor witch this jack does not have. Also steering gear reads zero at center. this one has me.... thinking main controller. any imput would be helpful.
  • Posted 11 Jan 2013 10:04
  • By ifsmike
  • joined 7 Jul'11 - 50 messages
when all else fails ,stand back and observe
I've seen there control's fail if incorrect horn is used. Very sensitive to spikes from excessive horn use.also be aware of software conflicts between new and older controlers.new version controlers need to have a new tillar card fitted to match software..your local dealer will help
  • Posted 13 Jan 2013 19:00
  • By kevin_k
Update. Problem found. After all this it is in the controller. Someone gave me one to try and after calibrating every thing high speed works. So now we send out the controller ( lskra ) to be repaired. Thanks for the responses. This was a good one. But I learned something and education cost money..
  • Posted 13 Jan 2013 02:56
  • By ifsmike
oops my mistake, origionally posted to check initiation circuit but you said in origional post controller is showing input from rabbit control... sorry bout dat ;o)
what about brake? is it electric? is it adjusted correctly? check it and make sure its not dragging
  • Posted 13 Jan 2013 02:38
  • Modified 13 Jan 2013 02:40 by poster
the controller is iskra?
  • Posted 12 Jan 2013 05:55
  • By forklift_brazil
  • joined 15 Nov'12 - 108 messages
  • rio de janeiro, Brazil
tecmanuais@yahoo.com.br
skype:hyster.brasil
Hello ifsmike
the maintenance reminder is active?
or you have disabled the display?
the pallet truck will slow down
you need the service manual?
you need the manual display access?
  • Posted 12 Jan 2013 05:43
skype:hyster.brasil
MPE060LRN24T2748 ,B896N01527D power steering ,no codes. Checked history and reset maintenance reminder. Tiller card was changed.
  • Posted 12 Jan 2013 00:58
  • By ifsmike
full model and serial might be more helpful ;o)
  • Posted 11 Jan 2013 21:34
Hi Ifsmike, is this the same truck that you posted on the 5th feb 2012,
Regards Titus
  • Posted 11 Jan 2013 20:28
  • By Titus
  • joined 6 Jul'10 - 185 messages
Regards Titus
  • Posted 11 Jan 2013 20:27
  • By Titus
Hi Ifmike, what year is this truck dose it have a Zappy controller or a Curtis controller, it seems this unit is locked into a slow speed mode
Regards Titus
  • Posted 11 Jan 2013 20:11
  • By Titus
Ice 24INCH-AUTO-SCRUBBER
USD6,396
Toyota 02-2TD20
Muncie, IN, United States
Deborah Baker Deborah Baker
