yale gp080vx code 653-6
Hi everyone! I have a gp080vx It has a gasoline only vortec 4.3 v6. The unit will start and run for two seconds then shuts off. The original problem is that the unit had sat so long with old gas. drained the gas installed new gas and still the same problem.I went into the display and cleared the codes then it ran about 30-45 seconds until codes popped up and then shuts the truck off.If anyone has a manual i would greatly appreciate it. email [email address removed] the code popping up is a 653-6 and before i erased the code history i believe it was a 654-6,652-6,656-6. The fuel pressure is 58 psi +-5.
  • Posted 3 Oct 2013 11:26
  • By fixnproblems
  • joined 19 Jan'13 - 66 messages
DTC 652-6 - GM Gas Injector 2 Drive Circuit Shorted To Ground
DTC 654-6 - GM Gas Injector 4 Drive Circuit Shorted To Ground
there is no 656-6 DTC in the list
check the injectors make sure there are no shorted circuits
check wiring, plugs
- remove the coresponding plug on the injector in question, then remove the plug on the ecu with the same coresponding wires, ohm out the respective wires on ohm scale, if resistance is less than 0.5ohms then repair the shorted wires.
- if no short found in wiring then check the coils in question
using same ohm scale measure between pins on injector coil, if reading is less than 2ohms 0.5 then coil is bad, replace it.
- if reading is ok then ecu is bad.
during testing the wires and coils use these wire numbers
WIRE # 857 (WHITE) = INJECTOR 2 CONTROL DRIVER
WIRE # 861 (WHITE) = INJECTOR 4 CONTROL DRIVER
wire 751 being the common wire in all injectors
hope this helps
  • Posted 26 Oct 2013 22:25
JLG 600AJ
JLG 600AJ 2012
Flesherton, Ontario, Canada
Taylor TT300
USD98,500
Dallas, TX or Lexington, KY, United States
Tacoma, WA, United States
Orlando area, United States
Highland, IL, United States
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
