Yale GLP060ZGEGAE087:
Yale Glp060ZGE
Hi, this lift has a GM with Spectrum fuel system. It runs good but the exhaust smells very bad, I suspect it's unburnt fuel. I thought it would be the vaporizer but this didn't help. Any ideas on what else may cause this. Thanks
  • Posted 18 Nov 2016 03:54
  • Discussion started by garland_s
  • Tennessee, United States
Well as of now it looks like it was the fuel, I put a tank on it filled from a different source and the smell went away. I know it sounds crazy but I think their tank got really low and they filled lift up and it picked oil up out of the bottom of their big tank.
  • Posted 20 Nov 2016 01:33
  • Reply by garland_s
I'm pretty sure it has just a muffler, it looks the same as some I've changed before. Most of the time if it has a cat there is also a muffler right after. I'm gonna bring a tank from home and try a different fuel source and if that doesn't change it I'll try a tune up again just to be sure. Tune ups fairly cheap. I did look at the plugs and they look good, but the gap did look a little big(46 th) I'm not sure what it should be. Thanks for your help and I will let you know how it goes tomorrow.
  • Posted 18 Nov 2016 10:03
If it has a catalytic converter it will have a O2 sensor in the exhaust. It will also have a ECU.
  • Posted 18 Nov 2016 05:42
  • Reply by BREWSKI
Parts book shows a cat converter for this but it looks exactly like a muffler to me. Usually there's a muffler and a cat right? This ones not stopped up, if they act like one on a car when it starts smelling like rotten eggs and exhaust stops up
  • Posted 18 Nov 2016 04:55
Electric lock off, I'm really starting to think it's the fuel. It smells almost the exact same as the exhaust
  • Posted 18 Nov 2016 04:52
The converter will change the smell of the exhaust. Does this truck have the vacuum lockoff? Check to make sure propane is not coming through the vacuum line.
  • Posted 18 Nov 2016 04:33
  • Reply by BREWSKI
I had an extra one so I just replaced it. I did a tune up less than 2 months ago. I did notice that the propane itself has a funny smell, I'm wondering if that could be it. They have a Toyota lift here also that doesn't smell but with the different vaporizer and a catalytic converter it may not smell.
  • Posted 18 Nov 2016 04:27
I would start with a basic tune-up if you haven't done one yet. Have you drained the regulator recently?
  • Posted 18 Nov 2016 04:20
  • Reply by BREWSKI
Sorry I didn't specify in my original post but it has the 3.0 in it if that makes any difference
  • Posted 18 Nov 2016 04:14
Operator said that it lopes like it has a cam sometimes. I've run into that on the Mazda when the injector goes bad but never on the spectrum
  • Posted 18 Nov 2016 04:05
No sir it doesn't. it smells like the oil that builds up in vaporizers
  • Posted 18 Nov 2016 04:03
Does this truck have a catalytic converter?
  • Posted 18 Nov 2016 04:00
  • Reply by BREWSKI
