Yale GLC070 Crankshaft keyway
How many have had trouble with this keyway egging out? I know of at least one other. Just checking in to see.
  • Posted 13 Feb 2010 10:16
  • Discussion started by proshadetree
  • Tennessee, United States
Thanks I am passing this on to the tech in the shop working on truck.He has welded the crank as per customers request and remade the key way. I cant tell it from factory. Will post back to let everyone know how this works out.
  • Posted 18 Feb 2010 08:49
  • Reply by proshadetree
Hey Pro,
I have not seen this happen but just checked bulletins for this engine. The crank pulley torque has been changed to 99 ft lbs plus an additional 45 degree turn. Also use loctite when installing the bolt. Not sure which one, will try and find out. This may have been the cause of your problem.
  • Posted 16 Feb 2010 00:37
  • Reply by garland_m
  • Virginia, United States
Work Hard and Fish Long
By the way its on the gm 2.4
  • Posted 14 Feb 2010 02:25
