Yale GLC050:
Yale GLC050DE hydraulic control valve test port
Hi all. I have an old Yale GLC050DENUAE083 S/N A823N02021T. I recently had the engine out to fix some broken motor mounts. I drained and changed all fluids while I was at it.
After reassembly, on the test run, everything worked great. Shortly after, steering became stiff, but would operate as normal if I applied slight pressure to the 4th lever (accessory not attached). After using it for a bit, the steering returned to normal. Now, it is stiff again. The other hydraulics work as they always have, pretty slow unless you rev the engine.
I have the service manual, but it is lacking (used to the Army -10, -20 manuals). It tells you to check the pressure on the inlet of the control block and that there is a test port there, but it does not show the port. I assumed that it was the smaller plug and tried testing, but never got a pressure reading unless I activated the 4th lever.
Can somebody tell me what I am doing wrong and where I can get a better manual (including the parts manual)? Thanks in advance.
  • Posted 22 Jul 2022 10:06
  • Discussion started by Anthony_Krebs
  • Kansas, United States
Anthony
Swoop,
Thank you for the reply. I was on the right track. I will take another Crack at it on Monday and update this thread.
  • Posted 24 Jul 2022 10:21
  • Reply by Anthony_Krebs
Anthony
anthony,
where the main line from the hyd pump connects to the hyd control valve check that fitting, it should be a largish 90deg elbow where the main line/hose connects to the control valve. If there is an 1/8in pipe plug in it that is where you connect your gauge to to check hydraulic pressure from the pump. It may also have a oring plug or a cap in the main inlet valve section where you can connect a gauge, there will be the same for checking the secondary pressure as well in the opposite side of the control valve in the auxiliary sections. There are also a main and secondary relive valve with an adjuster nut on top where you can remove the top and check the spring inside it and see if it is broken if need be.
If you do not find any plugs to connect a gauge to then you may have to do it the old fashion way by installing a Tee fitting inline where you can connect a gauge that way. (yes you may have to visit a hydraulic shop to get those, if so make sure you know the size of the fitting or remove it and take it with you so they can get you the correct one). Yale was pretty good about providing a test port in the inlet section and the auxiliary section so you probably won't have to go through all that.
Low pump pressure can cause steering problems because the steering gets it's pressure from the control valve that goes through a priority valve located down on the transmission area. The pressure from the pump should be around 2200 secondary to 3100psi at primary relief pressure. I'm not specifically sure the exact pressure because i do not have the service data for that truck, but the trucks in that series generally had close to the same pressure ratings, they haven't changed that much over the years.
Maybe someone else here does have the service data on this DE series and can correct me if i'm off too much. (just remember the pressure should never exceed the hose ratings and those should be printed along the hose).
Oh yes, almost forgot to tell you, make sure your test gauge is at least a 5000psi rated gauge.
  • Posted 24 Jul 2022 07:57
  • Modified 24 Jul 2022 07:59 by poster
  • Reply by swoop223
Louisville, KY, United States
Dubuque, IA, United States
