yale glc040afnuae082 b809n03060a
where is the neutral saftey switch on this machine? There is 2 plunger switches for for/rev near the selector, smh says it has a micro switch, I dont think it can operate w/ a micro w/ this design.
The machine will start in gear or neutral, is it located w/in the trany soliniod.
thank you
  • Posted 17 Apr 2012 04:42
  • By 7777
The yales i work on have their relays up under the dash on the left hand side under a plastic or metal kick plate cover- hope it helps
  • Posted 18 Apr 2012 23:51
  • By bbforks
I replaced the 2 plunger switches, and the problem was resolved. I think when the switches are in the normal position, (up), they are grounding the 4 wire soliniod on the transmission, and this soliniod might act like a relay closing the cqt. to the start soliniod. I can't seem to locate a start relay on the machine.
  • Posted 18 Apr 2012 05:51
  • By 7777
7777- I'm not familiar with your exact machine but from your description I would believe that the 2 micro or plunger switches would act as a nuetral safety switch- I haven't seen a 3rd switch or the use of the solnoid on the trans for this purpous as of yet. Does it start in both frward & reverse?
  • Posted 17 Apr 2012 23:22
  • By bbforks
Terberg RT403
Toyota 3FD100
ROYPOW
ROYPOW
Muncie, IN, United States
