YALE DASHBOARD PROBLEM
Yale ERCO60 S/N.E108V177512B.Dashboard Problem After shutdown the dashboard stay's on
and the only way the db turns off disconnect the battery.Could this be a common problem?
Your H E L P is Honored.
  • Posted 1 Jan 2009 01:30
  • Discussion started by LOGIC
Going to hav dashboard check out,post my results.
  • Posted 5 Jan 2009 23:28
  • Reply by LOGIC
You may want to check your light harness in the back of the truck? They hide a diode in the rear harness. Just a thought. ETS1
  • Posted 5 Jan 2009 10:21
  • Reply by ETS1
  • New Jersey, United States
try a new dash. they are not the most reliable.just check the power is turning off. easy test ,one of the middle pins in the plug will show you voltage at key on and nothing at key off. if not ,it must have a short somewhere
  • Posted 1 Jan 2009 19:43
  • Reply by kevin_k
Key off ,all other function work,except dashboard if u say the cap is to be discharge and not do i replace or fix dashbaord
  • Posted 1 Jan 2009 10:33
  • Reply by LOGIC
when you turn key off you should get meter reading then blank backlight stays on for a bit till capacitor discharges. is your keyswitch turning off ??
  • Posted 1 Jan 2009 03:50
  • Reply by kevin_k
Hangcha CBD15
China
USD1,600
TCM FHD105Z
