Hyster H50FT:
Won't stay running
My forklift starts for a second and then dies won't stay running any ideas
  • Posted 15 Dec 2024 08:09
  • Discussion started by Ken_Guest
  • Utah, United States
Kenny Guest
What engine lpg or diesel??
  • Posted 21 Dec 2024 18:21
  • Reply by lifter01
Ken,
There can be multiple issues to cause this. I guess this lift runs on propane. First, make sure the coupling for the tank is completely seated and that the seals are not damaged, tank is full of propane. Have found LP tank full of water. Look at the wires for the LP lock off. These could be loose or worn. There may be an issue with the ECU. Two signals for crank then run. Also, the LP converter will open initially for key on, then shut down, open again once the starter is engaged. Any codes showing on the display?
  • Posted 16 Dec 2024 23:54
  • Reply by Fishmech
  • Virginia, United States
Your Focus
Toyota 8FD35U
Flesherton, Ontario, Canada
JLG G12-55A
