Won't start
Trying to revive my old forklift. Yale GLC030CBJUAF083 Sat out side for a year. Tried to start it but no spark. Bought the ignition module now have spark. It just sputters and tries to start some what. Even with ether it's the same thing. Any Ideas?????? Thanks !!!!!
  • Posted 7 Apr 2017 03:36
  • By Oarwhat
  • joined 7 Apr'17 - 2 messages
pull the spark plugs and squirt a little bit of oil in each cylinder
if the plugs look bad put new ones in it
see if that helps the compression issue, it should get up to top compression in just a couple of revolutions, the oil will help loosen up the rings that are probably stuck from sitting.
check the air filter also, try cranking it without it and see if that makes any difference.
  • Posted 7 Apr 2017 12:17
We did that and got 130 to 150 PSI. It did take quite a few revs to get to max though.
  • Posted 7 Apr 2017 06:16
  • By Oarwhat
Run a compression check. Valves tend to get sticky when the truck sits.
  • Posted 7 Apr 2017 06:09
  • By BREWSKI
Linde C4230TL5
Advance CS7000
Illinois, United States
USD8,000
edition #1237 - 3 July 2025
UN Forklift FD35T
SMV (Konecranes) 33-1200C
Saratoga, United States
Columbia, SC, United States
East Syracuse, United States
