Yale MPW060LEN24T2748:
Won't lower
This is a MPE060LEN24T2742 SN#B897N01768S. It will not lower, on going issue. Curtis handle held displays that its getting a lowering input signal, the main contactor, hydraulic valve assembly and lowering coil have been changed (new) but still can't get it to lower continuously. (SPARATIC) at first I could mess with it and get it to lower. Now can't, any ideas?
  • Posted 3 May 2022 00:33
  • Discussion started by Tony_Briggs
  • Missouri, United States
Does it have a bent or damaged lift cylinder or the lift linkage rusted/ dry?
Chunk of wood wedged in the linkage?
The hydraulic valve on the pump is only a lowering valve that opens a pathway back to the tank and the forks lower by gravity. So if any of the above happens.
Will it lower with a load on the forks?
  • Posted 21 May 2022 01:40
  • Reply by Keith_Runnells
  • Wisconsin, United States
Ditchchickens
VETTER Forks, Inc.
Jefferson, WI, United States
Johnston, IA, United States
St. Louis, MO, United States
edition #1234 - 12 June 2025
Zhejiang UN Forklift Co., Ltd
