Wont drive
Still Rx70-25
Modell: 7322
År: 2009
The forklift is equipt whit
Acellerator singel pedal dobbel poti -Fabli - Joystick - CPP1 - CPP2 - CPP3 - CPP4
Everything works but the driving dossent.
aktivate direction forword and depress acellertor the indikcator turn off and nothing happends.
There is no error codes on the forklift ore the engin controll.
Diagnosiss ses that I\m missing the relase signal for accelerator.
anny idea?
  • Posted 12 May 2022 05:14
  • By sjoold
  • joined 24 Oct'15 - 25 messages
  • Norge, Norway
if no error maybe minor problem, need to check all cable and connection, connect correctly, if not solved, use navigator and check active error. as per error start troubleshooting..
  • Posted 25 Jun 2022 03:27
  • By muzffar_h
  • joined 25 Mar'19 - 12 messages
  • United Arab Emirates
Hello
The traction converter under the air filter should be checked.
  • Posted 24 Jun 2022 06:13
  • By FrenchTech
  • joined 15 Mar'22 - 11 messages
  • France
French Technician
Still Linde Fenwick Jungheinrich
In measurement section of Diamon go to status and check converter has released drive. Sounds like potential converter issue as these can fail without causing error code.
  • Posted 19 May 2022 16:24
  • By simon_k
  • joined 31 Oct'04 - 147 messages
  • Devon, United Kingdom
Lift Tek Elecar
