Won't Drive, Mast and steering work fine
Inherited this truck (2FBE15) in a building we purchased. Will not go forward or reverse. All mast functions work fine; when key is on and lever moved to forward or reverse position, hydraulic motor engages and steering woks. I checked the two switches that accelerator actuates, they are good. Checked all fuses I could find. I need a wiring diagram and some ideas!
Thanks in advance.
  • Posted 12 Feb 2018 06:43
  • By RickB
  • joined 12 Feb'18 - 1 message
Rick
Toyota 2FBE15
Did You get the Unit to work, We have the same Problem , did You get the wiring schematic? Please let me know. Thanks
  • Posted 10 Apr 2026 02:16
  • By MM2952
  • joined 30 Jan'16 - 13 messages
M. Moreno
If you need , i have a power unit complete to help you.
Unplug the battery, open down left plate and, side wheel open the little black plate and check contactors if welded.
Side right, open other plate, acces to power unit.
Regards,
BB2K
  • Posted 6 Mar 2018 08:18
  • By BB2K
  • joined 26 Feb'18 - 8 messages
  • paca, France
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
