water in the hydraulic tank
Does anyone know a good way to get all the water out of a hydraulic system, other than draining and replacing fluid many times over
  • Posted 15 Mar 2011 04:22
  • By 7777
Thank you again
  • Posted 15 Mar 2011 18:29
  • By 7777
An air operated pump cuts down on the time a lot, just pump the oil out; when you are ready to refill reverse the pump, pump about a gallon of new to clear the pump and lines and then proceed to refill.
  • Posted 15 Mar 2011 08:37
  • By cownd
  • Arizona, United States
orchidlane29@gmail.com
Thank you, I guess filling 1/2 way will save some oil, but I think this is going to be a long process
  • Posted 15 Mar 2011 08:18
  • By 7777
That's the only way I know of, try draining and refilling but only half full, cycle the hyd's several times and repeat at least two more times or until the fluid appears clear. You can take one step further and sample the fluid after it clears up.
  • Posted 15 Mar 2011 07:12
  • By cownd
Aichi SR10C1SM
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Hyster
Aichi SR10C1SM
USD1
