Linde (& Baker) H35T:
Vw engine, cranks but no spark and seems to be no fuel flow. lpg
s#H2X393R05793
I have a Vw engine linde fork lift, customer stated one day it died on them to never start again, it had sat for a year or 2 now and now they want it fixed. started off with replacing ignition system due to transformer had blue corrosion on spark side, replaced plugs, wires and transformer. still will not start. checked and verified voltage to power wire on transformer, verified ohms on pins 2, 3, 4 and 5. (does the brown ground wire just go to ground?) verified power to control module, checked all fuses and verified fuses are getting 12 volts. stumped on this unit. really thought replacing the corroded transformer would fix the concern but now it seems I may have other bad components or bad wiring somewhere keeping me from firing. all the wiring I have checked thus far seems to check out, only interesting thing i found that may be cause for concern is that I only seem to get.430v on the og/gy positive wire from pin 11 on connector on1. it also didnt seem like i was having any fuel flow. is there a specific parameter the control modules are looking for before they start fuel flow and ignition? im almost leading towards a module for this unit but am terrified to call one as i am newer to fixing forklifts, nevermind vw forklifts.
any help is much appreciated, thanks for your time.
  • Posted 29 Sep 2022 10:05
  • Discussion started by TrustB4Treason
  • British Columbia, Canada
there is a black pulse sensor in starter gear housing is it good???????????
  • Posted 2 Oct 2022 17:39
  • Reply by michel_v
  • noord holland, Netherlands
Do you have a picture of what ignition is in it?
  • Posted 2 Oct 2022 16:51
  • Reply by michel_v
Hangcha CPYD32XW71F-C
Flesherton, Ontario, Canada
Hangcha CBD15
China
USD1,600
Johnston, IA, United States
St. Louis, MO, United States
Jefferson, WI, United States
UN Forklift FD35T
Hangcha CBD15
China
USD1,600
Enforcer FLBAXT25
GemOne
