Toyota 8FGCU25:
valve body/transmission
have a lift that does not go into forward. the direction switch is ok and so are the solenoids.
I took a valve body off another forklift and the lift worked fine. After 6 hrs of opperation the very same symptom returned.
Now I have two valve bodys that do not go into forward.
I do have pressure out of the main, the reverse, but not the forward.
thanks
  • Posted 24 Aug 2012 03:24
  • Discussion started by bowlerwa
  • Washington, United States
been a while since this post but im having similiar problems with an 8fgcu25, little to no pressure in fwd,solenoids working. did you find sticking valves in the valve body?
  • Posted 23 Jan 2015 09:44
  • Reply by gordie
sorry for not replying sooner.
What I did was take apart the valve body and clean everything up and then changed the oil. It worked and is still working.
  • Posted 1 Dec 2012 06:54
  • Reply by bowlerwa
i think you have a bad forward and reverse relays or the harness in it
  • Posted 5 Sep 2012 11:55
  • Reply by forkliftcity
  • cebu, Philippines
don't bite the hands that feed you!
edition #1228 - 1 May 2025
Louisville, KY, United States
Dubuque, IA, United States
ROYPOW
Ncn 85TH
Ncn 85TH 2017
SMV (Konecranes) 16-1200C
