Vacuum Issue/MAP Sensor
Have a Doosan GC25E-3, serial JZ-00180. Mitsubishi G424E engine with a woodward regulator and mixer. Original complaint, engine stalling and misfiring. Retrieve ECM codes. Found code 27. Checked vacuum at intake. Had no vacuum. Removed mixer. Found bottom of the plunger broken. Replaced mixer. Test and found engine still had misfire but not stalling anymore and vacuum restored. Did tune up, plugs, cap, wires, rotor. Engine running smoothly. Returned to service. Four days later, called back out. Engine stumble???? Check issue. Found engine to stumble intermittently at idle and through RPM range. Removed air intake from mixer. Found the plunger inside the mixer opening (plunger moving down) on its own, like someone is feathering the throttle pedal. Does this through RPM range as well. Checked manifold vacuum. Found that when the issue presents itself, the vacuum drops from 17 inches to around 6 inches but then catches itself... Never stalls out. I was certain that the throttle motor was bad, so I changed it. Still same issue. Swapped throttle motor back out. Checked for codes. No hard codes stored, however when the engine stumbles, the MIL light will flash 1 time. Unplugged foot TPS, O2 sensor and ECT sensor. Issue remains. Here is where it gets interesting. If I unplug the MAP sensor the issue goes away but I then have no throttle response. Renders the throttle motor operation. Any info or help would be greatly appreciated.
  • Posted 15 Sep 2015 10:18
  • Modified 19 Nov 2015 12:45 by poster
  • By LTS1
  • joined 18 Dec'13 - 74 messages
Trim valve controls vacuum to lean or richen the fuel system. Usually either 1 or 2 of them located near the fuel regulator. They are plastic. Round in the middle with tubes on top and bottom that have vacuum lines attached to them. There is also a 2 wire plug connected at the round part. Electronically controlled. Google the part number A343009 for a picture. Hope this helps.
  • Posted 3 Feb 2019 03:11
  • By LTS1
What is the trim valve and what does it look like
  • Posted 31 Jan 2019 06:22
  • By lynn_m
  • joined 11 Nov'18 - 7 messages
Replaced trim valve. Issue resolved. Hope this helps someone.
  • Posted 19 Nov 2015 12:43
  • By LTS1
Replaced MAP Sensor, no change no go. Still troubleshooting.
  • Posted 21 Sep 2015 10:49
  • By LTS1
Also checked regulator pressure. It has a solid 2, 2 and a half pounds of pressure all the time. Removed cover from regulator. Signs of minimal tar build up. Clean for the most part. Really stumped on this one. Also checked PCV valve, trim valve, vacuum hoses, checked for vacuum leaks, checked dry vapor hose etc....
  • Posted 15 Sep 2015 10:21
  • By LTS1
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Taylor TE650S
Unicarriers FD80-2
ORDER PICKING
FLEET MANAGEMENT
SAFETY SOLUTIONS
