Unit won't start...
Unit was running then cut out while driving, found broken negative terminal inside battery. Replaced battery but unit will not start. Have propane to carb, regulator good, all 4 plugs getting spark. Cannot figure this one out, have fuel and spark, should start, tried ether into carb still not catching. All electrical connections look clean and are tight, all connectors tight. Thinking when battery broke it may have shorted out something in the electronics. Any help would be appreciated.
SN: D010H0152Y
  • Posted 14 Mar 2014 06:06
  • By ddaar
  • joined 5 Oct'13 - 11 messages
I think you need to check the compression with a gauge. It may have a timing belt problem that threw off the spark timing and/or compression.
  • Posted 15 Mar 2014 05:34
The post inside the battery broke somehow. Said he pulled each plug and tested for spark by grounding them and cranking the engine, all were good, also checked compression at that point, checked out good, though I don't think he did an actual compression check with his gauges, air filter is new, well, maybe a month old. Sprayed ether and engine did nothing he said. Electric lock off is working. 5028 hours on unit, we just got the contract so not sure what all has been done to the unit for the from this point back. Any help would be appreciated. Thanks.
  • Posted 15 Mar 2014 01:16
  • By ddaar
When you say broken negative terminal inside battery, do you mean the negative battery terminal connector broke? You need 4 things for an engine to run. Air, fuel, compression and spark. If you have good compression and you have spark at the spark plugs and you have fuel, unit should run. The fact that you have spark tells me your electrical/ignition system is operating. If you spray ether in the carb and you have spark, it should at least try to run momentarily. Do you have a vacuum operated lock off or an electric solenoid type lock off for fuel? How many hours on unit? How do you know plugs are firing? Need more information to properly help you.
  • Posted 14 Mar 2014 12:19
  • By LTS1
  • joined 18 Dec'13 - 74 messages
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
Tommi Haavisto Tommi Haavisto
Director of sales, EMEA & APAC, Hiab and MOFFETT Truck Mounted Forklifts
Regional director for UK & Ireland, TVH
President - business area port solutions, Konecranes
President, Logisnext Europe
