Crown FC4525-50:
Unit Bucks under light acceleration
fc4525--50 ac drive motor, regular pump and steer motor. unit bucks forward and reverse when under light acceleration with or without a load
i have replaced the access 3 traction controler
accelerator pot and switch
brake switches
encoder in drive motor
checked wiring between encoder connector and main connector on traction controller--pass
battery doesn't lose more than 4 volts while driving
battery is out of unit and still has same issue
had code 314 very rarely, hasn't come back on since encoder replacement
  • Posted 7 Dec 2022 05:04
  • Discussion started by BigForker52
  • Alaska, United States
Located in the north north
UK Forks adds electric Loadall Derbyshire, United Kingdom
Rocla AGV Solutions
Leading developer & manufacturer of automated guided vehicles (AGVs) tailored to the customers' specific needs.
edition #1130 - 1 June 2023
You might notice a few changes in your newsletter and on our website. That’s because we updated the format last week to make it even easier to read – and to... Continue reading
VETTER Forks, Inc.
Lincoln was known to have more than one stovepipe hat, each typically seven or eight inches tall. It is said that hats were important to Lincoln: They protected him against inclement weather, served as storage bins for important papers he stuck inside their lining, and further accentuated his great height advantage over other men.
