Tugger trains vs forklifts
comments please
  • Posted 20 Jun 2013 19:54
  • Discussion started by Malaysian
  • Johor, Malaysia
Showing items 1 - 15 of 41 results.
Checked with my mfg contacts as promised and here's what I was told.
* The advertised draw bar pull specification is exactly what the definition of draw bar pull is (see below). Draw bar pull can pertain to towing a disabled forklift, towing a trailer, locomotive pulling rail cars, farm tractor pulling a bottom plow etc... as long as you remain within the manufactures draw bar pull specification I don't see the issue. Draw bar specifications for any type of equipment that requires a draw bar pull specification are calculated taking into consideration center of gravity, braking, converter stall, horse power (IC or Electric) etc...
o Drawbar pull is the pulling force, or pulling ability, of a vehicle. The definition of drawbar pull is the towing force of a truck or other industrial vehicle, exerted at its coupler (or equivalent) in the direction of motion of the coupling point. Drawbar pull is typically expressed in pounds or Newton's
  • Posted 12 Jul 2013 03:20
  • Reply by cownd
  • Arizona, United States
orchidlane29@gmail.com
yes karait, it is refreshing to see so many different personalities come out about different subjects here. Some are more passionate about it than others but in the end it helps broaden ones perspective view a little bit (if they have an open mind that is) ;o)
I personally tend to lean towards intention of design and specs and through experience have learned there is always a grey area you can work in but generally it always pays to 'tow' the line so to speak and use equipment as it was intended to be used. There are some that push the envelope a bit, sometimes successfully and other times not. When your dealing with an expensive machine though and also with legalities and safety there are alot of things to consider using equipment.
One thing i've learned over the years is 'if it can happen it will'.
Meaning you can think of everything, every scenario to try and prevent bad things from happening but its the things you didnt think of that usually come up and bite you in the rear ;o)
Just some thoughts to add.....
good day all
  • Posted 12 Jul 2013 03:03
  • Reply by swoop223
Well, I see the simple subject caused some emotions ;-)
Relating some previous topics.
I think the Linde salesman would confirm in written the possibility of using his truck for towing, just to underline the advantages of hydrostatic transmission and brakes.
Concerning the safety issues.
I dont know what is the difference between towing dead truck with another truck and towing some trailer.
What is the technical difference (traction, brakes) between the towing wehicle with lift mast and without it. Frankly, if you take the mast off the truck you get something pretty similar to the tractor.
Some trucks even look like tractors with additionally mounted masts.
The traction and braking abilities of towing tractors and forklifts are not very different.
One more remark.
My private sedan was not designed to tow the trailers either, but when I installed a hook (and registered it) I could attach the light camping wagon (with proper mass ratio) and travel over several european countries without any legal problems.
  • Posted 12 Jul 2013 02:07
  • Reply by Karait
  • Poland
I'm quite sure that if a salesman was asked to put in writing with his/her signature that a forklift could be used as a tugger on any occasion the answer would be no.
When a question is vaguely answered or addressed in a brochure or literature there's a reason. There's never a question about lifting height, weight capacity, etc. Isn't it interesting that when this question is raised, there are so many interpretations?
I'd love to see what OSHA would have to say on this subject if someone got hurt using a forklift as a tugger with company approval- I bet they'd have no trouble interpreting this question.
  • Posted 10 Jul 2013 03:00
  • Reply by bbforks
I know Linde for there hydrostatic 392 & 394 machines state in the operators manual that a rigid tow pole should be used.
The tow bar on the truck is really meant for moving a broken down forklift / vehicle out the way, its not really designed for everyday operational towing use.
In 7 years we have used it once to move a van that was stuck in the snow.
  • Posted 6 Jul 2013 23:37
  • Reply by Forkingabout
  • england, United Kingdom
well cownd your spec sheets roughly reflect the weight of the trucks relative to thier drawbar tow specs. Whats that tell you? ;o)
  • Posted 6 Jul 2013 12:12
  • Modified 6 Jul 2013 12:13 by poster
  • Reply by swoop223
Thank you johnr I.; I have one year less than you but still active. I hear what you're saying but would like to use your suggestion to find out the opinions of the manufactures.
I have a few spec sheets here in my office and for drawbar pull the first three show the following.
* Yale/Hyster
o 120VX/7,000 lbs draw bar
* MCFA/Cat/ Mitsubishi
o DP50KN1/6,000 lbs drawbar
* Taylor
o TX160/14,360 lbs drawbar
Monday I'll contact each and ask what their interpretation is for their specification pertaining to drawbar pull. I'll share the findings should be interesting.
  • Posted 6 Jul 2013 08:36
  • Reply by cownd
Crowd: Ask Yale for their interpretation, they are the manufactuer or their authorized representative (aka dealer).
I mentioned in an earlier post when sizing a tow tractor a basic rule of thumb is one lb of "CONTINOUS" draw bar pull (DBP) can pull a rolling load of 50 lbs on a level surface (most warehouse & plants) actually have a ~1% pitch for drainage purposes) with low friction tires (say steel) at the stated loaded travel speed. Clark used to publish such an application sizing booklet when they were in the tow tractor business & had their tractors at every airport I ever flew out of for a longtime - TUG took over whem Clark got out of the business (the TUG looked just like the Clark).
Do the math following your reasoning. The published DBP of a counterbalance lift is the MAXIMUM rating of the unit - which maybe (depending on the manufactuer) at motor or torque converter stall or a 1 mph (which most Japanese companies publish) and their numbers are lower than many US brands. You DO NOT want to operate a motor or tranny at stall for any length of time unless you have a real big checkbook and down time is not an issue. I have yet to see a lift truck company publish a continous DBP rating for a counterbalanced lift truck and my career in industrial lift truck industry started in 1967 & ended in 2007 (retired) with four different companies. Besides developing tech manuals I had a very extensive back ground in lift truck spec. sheet development and evaluating competitve equipment as well as their collateral material. Granted things may have changed since September, 2007 but I doubt it. I know I have changed my hair is a little grayier, I wear glasses now but my BP is in the 120 's.
  • Posted 6 Jul 2013 06:40
  • Reply by johnr_j
"Have An Exceptional Day!"
Thanks johnr j, I agree with your parts manual comment but I was just using that as a reference point. According to a Yale 120VX operators manual the "tow pin" is to used for towing a disabled forklift with another forklift and as a tie down point for transport, as motioned earlier. If you have disabled forklift @ 17k lbs being towed by another forklift as recommended by the MFG what's the difference if you're towing a trailer as long as the gross weight does not exceed the MFG's maximum draw bar tow spec?
  • Posted 6 Jul 2013 02:21
  • Reply by cownd
cownd,
What does the manufactuer's operators manual /operator training programs say??? This is the key document. They most often give the specific do's & don'ts as outlined by the manufactuer & those define by various requaltions like SAE (formerly ASME/ANSI) & OSHA. A parts manual basically gives an illustration, a lable to reference a part number, a written description (sometimes specs.) & but not much info about the function or purpose. Used to be a technical writer for parts, operators & service manuals and later operator training programs all for industrial forklifts.
Calling a pin a tow pin could mean a point to which a "dead in the water" forklift can be "towed" to a repair area or on to a tilt bed deliver truck equipped with a winch vs putting a chain aroudn the OHG legs or a forklift carriage bar.
  • Posted 6 Jul 2013 01:33
  • Reply by johnr_j
The difference in this case is that the end user is using a Linde Hydrostatic fork lift to tow with. The hydrostatic transmission has dynamic braking which will stop the load. In towing it is not as much to have the torque to pull the load but to have the braking power to stop the load. You can tow with a Torque converter forklift if you have enough braking power but I doubt the MFG. will stand behind the product in this application.
  • Posted 6 Jul 2013 01:28
  • Reply by Bucknut
I have to disagree with Edward T this time about tow pins vs. tie down points. If you check the forklift manufactures part books they still label these as tow pins furthermore, they provide a specification for that on the spec sheets. If you're going to use a forklift to tow use the manufactures recommend specification for that function.
  • Posted 6 Jul 2013 00:09
  • Reply by cownd
HELLO
WE ARE ALSO DESIGNING AGV TRACTORS in collaboration with ASTI SPAIN...if ever you need more info ¡ Our AGV products are EXACTLY IDENTICAL to standard Tractors , only new software ¡¡ Exceptional technolgy and worldwide first ¡
Rgds
cownd, those are no longer "tow pins" those are now "transport tie-down points". (big plaid button up shirt red-neck grin)
What it matters is how safe can you stop and/or steer a series of trailers vs how safe you can stop and/or steer a forklift that has picked up and is carrying a properly loaded pallet or '****' of materials around pedestrians, and just where the brakes are mounted to (it may not be the best idea to have the only brakes on the very front wheels of a train).
AND
if I was designing a warehouse that was going to use a "train", these days, I would sure be considering AGV's... wages are a continuing expense, AGVs are too, but not near as many wages per ton moved/hour operation 24/7
  • Posted 5 Jul 2013 00:20
  • Modified 5 Jul 2013 00:22 by poster
  • Reply by edward_t
Good afternoon ,
as Tow tractor manufacturer ,i strongly advise all industry logistics deiciders to think about Electric tow tractors ¡our range starts from 3 up to 30tons ,and we are looking for dealers worldwide....our customers are Airport , railway logistics,car industries ,hospitals, Airbus Industrie etc...do not hesitate to contact TECNA2000.COM¡
mail: [email address removed]
Hangcha CPYD25XW71F-JC
Flesherton, Ontario, Canada
JLG 260MRT
JLG 260MRT 2016
Louisville, KY, United States
Dubuque, IA, United States
