Troubleshooting: No FWD/REV
Having trouble with my residential workshop RC3020. I have spent 12 hours toning out wiring throughout the lift with every access panel and plate removed.
My FWD/REV performance has gone from intermittent to absent. Batteries at 38.6V; Amperage good; fluids good -- before your ask ;-) I was able to get "some" movement if I unplugged the batteries and inserted. Sometimes it operates, sometimes a single side of the FWD/REV solenoid clicks. If this happens then I need to unplug/plug to get flow.
At this point, I have performed the following diagnostic steps:
+ verified main power solenoid function
+ verified that all connection solenoids operate correctly with 24V
+ chased all signal wires/leads from solenoid to ECU
+ ohm'd the micro switches on the control stick
The lift and tilt are still working fine. The steering drive is operational.
What am I missing? At current, the only solenoids operating are the main power solenoid and the hydrolic pump solenoid. I'm not hearing or seeing the other solenoid/switches operating. I "think" I'm only getting 18V to these solenoid/switches.
Other tips from people far smarter than I?
Thanks!
/jm
  • Posted 4 Jan 2012 08:46
  • By joelmcf
  • joined 4 Jan'12 - 4 messages
I know this is an old thread but I am having the same problem, do you remember which card or board it was?
  • Posted 21 Feb 2019 14:43
  • By HelpMeLift
  • joined 21 Feb'19 - 1 message
it was a bad card.
  • Posted 6 May 2015 12:52
  • By mechNtraining
  • joined 4 Dec'14 - 35 messages
  • Oklahoma, United States
Do it Today or Tomorrow But You will Do it.
Check your brake switch, its under the brake pedal. then check the deadman switch. Clean off your contact tips for your fwd rev. check voltage at your solenoids for fwd rev. Check to see if your pot for fwd rev is centered (ohm it out to do so).....
  • Posted 6 May 2015 12:43
  • By Nettle
  • joined 6 May'15 - 1 message
  • Utah, United States
my bet/W.A.G. is he had bad contactors.
  • Posted 29 Apr 2015 20:10
That old post was from Jan. 2012.
What works and what does not work?
  • Posted 29 Apr 2015 13:38
  • By 1Crusader
  • joined 5 Oct'10 - 52 messages
I didn't do it, nobody saw me and You can't prove a thing...
WHAT DID YOU FIND out and what was the solution? As i have the same problem.
  • Posted 29 Apr 2015 13:08
  • By mechNtraining
Sue Tomic Sue Tomic
Bolzoni SpA (Group HQ)
Sue Tomic Sue Tomic
