Travel Tilt
After a trainee has been tested how important is it for a driver to carry on using travel tilt or is it down to the driver to use common sence, depending on floor conditions ??
Your view plz...
  • Posted 3 Dec 2011 02:34
  • Discussion started by ZZJASEZZ
  • BUCKINGHAMSHIRE, United Kingdom
I didn't realise you could obtain an NVQ in oprerating forklifts but, I think the ACOP advises that operators require to be refreshed although the time between refreshers is largely discretionary. My employers refresh every 3 years.
  • Posted 17 Aug 2012 21:42
  • Reply by ewan_d
  • Highland, United Kingdom
pride and professionalism protects.
if a driver has an NVQ in operating forklifts or plant does he still need to have a licence, and how long does the licence last for?
  • Posted 16 Aug 2012 22:22
  • Reply by BILLBO
  • YORKSHIRE, United Kingdom
  • Reply by BILLBO
How important?
We would teach it if it wasnt important.
Safery for the operator and anyone near the forklift including the load.
Simple.
  • Posted 12 Aug 2012 02:23
  • Reply by AceT
  • Hampshire, United Kingdom
www.acetrainers.co.uk
Forklift & Driver CPC Training Service's
Transport Consulant Service's
keeping the load engaging means or the load itself low (usually within 10 to 15 cm of the floor, depending on the condition of the surface) and tilted backward (when carrying a load, the load is tilted back only enough to support the load);
(Metric Conversion equals 4 to 6 inches.)
Isn't that what I said? lol
  • Posted 23 Jan 2012 13:50
  • Modified 23 Jan 2012 13:51 by poster
  • Reply by dan_m
United States
ANSI/ITSDF B56.1-2009
SAFETY STANDARD FOR LOW LIFT AND HIGH LIFT TRUCKS
4.4 Stability
4.4.4 Users shall give consideration to special operating conditions. The amount of forward and rearward tilt to be used is governed by the application. The use of maximum rearward tilt is allowable under certain conditions such as traveling with the load lowered.
5.3 Traveling
5.3.8 (c) On all grades the load and load-engaging means shall be tilted back, if applicable, and raised only as far as necessary to clear the road surface.
5.3.10 Travel with load-engaging means or load low and, where possible, tilted back.
Canada
Canadian Standards Association (CSA) B335-04
Safety Standard for Lift Trucks
4.9.3 Traveling
4.9.3.1 General
(h) travel with the load engaging means or the load itself low and where possible, tilted back.
6. Operator training requirements
6.10 Traveling with and without a load
The trainee shall be instructed on
(j) keeping the load engaging means or the load itself low (usually within 10 to 15 cm of the floor, depending on the condition of the surface) and tilted backward (when carrying a load, the load is tilted back only enough to support the load);
  • Posted 23 Jan 2012 08:29
  • Modified 23 Jan 2012 08:39 by poster
  • Reply by joseph_h
  • Michigan, United States
For the counter balance & reach trucks I look after if there unladen then just full back tilt is enough for the forks to easily clear the floor / ground.
Customer's driver trainers teach the operators on site full back tilt when unladen & enough back tilt to stabalize the load while laden.
  • Posted 21 Jan 2012 20:25
  • Reply by Forkingabout
  • england, United Kingdom
To continue, both the forklfit and the load are vying for maximum stability, however, we both know neither should get it. There must be a compromise, giving reasonable stability to the forklift, and its load.
If the forks are tilted slightly back, the load is sitting on a slight angle, resting against the load backrest, comfortably, and the center of gravity inside the stability triangle is not forced into the narrows of the triangle, hence, slightly tilted back. As mentioned, 2-3" at the heels and 4-6" at the tips is considered slightly tilted back, and since no operator will get out the truck and measure, the figures can be used as a reference.
  • Posted 21 Jan 2012 08:34
  • Modified 21 Jan 2012 20:42 by poster
  • Reply by dan_m
Constantly Lifting The Standard!
Both the ITSSAR & RTITB operator theory test have the same answer to the question of how much tilt is required when transporting a palletised load. Answer being Sufficient back tilt to cater fore the type of load and ground conditions.
  • Posted 19 Jan 2012 21:30
  • Reply by MaxaM60
  • Bristol, United Kingdom
Instructor, ITSSAR Cat' 4 Tutor
Whether loaded or not, the mast should be tilted slightly back at a height of approx. 2-3 inches at the heels, and 4-6 inches at the tips. Hence, slightly tilted back prior to movement. This will ensure that the forks are low enough to the ground w/o the forks/pallet rubbing the ground, and ensure that if someone is struck by the tips, damage, athough painful, would be minimal.
  • Posted 12 Jan 2012 09:57
  • Reply by dan_m
"When travelling unladen, the forks should be carried 4-6 inches from the ground with back tilt applied.
When laden sufficient tilt should be used to secure the load on the forks."
  • Posted 4 Jan 2012 21:42
  • Reply by ewan_d
Common sense would tell anyone that you should tilt back before moving off.
Training would confirm that as good operator practice.
  • Posted 22 Dec 2011 20:05
  • Reply by PPPA
  • United Kingdom
St. Louis, MO, United States
Johnston, IA, United States
Jefferson, WI, United States
edition #1234 - 12 June 2025
