Yale G83P-060-SBS-086:
Transmission cutting in and out
Transmission will stop engaging into forward or reverse and then "catch" as if it is finally able to find the fluid. the pump sounds like it might be getting air, fluid level is full. I have changed the transmission fluid using (Dextron atl fluid).
  • Posted 28 Mar 2017 22:40
  • Modified 28 Mar 2017 22:49 by poster
  • Discussion started by leon_y
Fat Daddy
Nero,
I found a inline filter on the suction side of the pump that was plugged up, I cleaned the filter and problem solved!!
Thanks for your help!!
Leon
  • Posted 29 Mar 2017 22:01
  • Reply by leon_y
I don't know this truck or transmission but it sounds to me like the sump take up filter might be blocked. On Yale trucks it may be located at the back of the transmission under a plate and gasket removing the plate you should be able to pull the filter and clean it. I'm just going of what I have experienced when I worked on trucks. It sounds like the pump is being starved of oil.
Regards Nero
  • Posted 29 Mar 2017 02:03
  • Reply by NER045
