trans grinding when going into gear
intermittently my hilo when grind when going in to forward gear why
  • Posted 29 Dec 2023 01:51
  • By edward_bayne
  • joined 29 Dec'23 - 1 message
  • Michigan, United States
grinding when putting in forward gear?
sounds like your going to need a new transmission (or a reman if available).
when you select forward the control valve sends fluid to the clutch pack assembly and tells it to move the clutches together so they will compress, works the same way in a car, there is one for forward and also for reverse, these drive drums where the discs go have teeth in them, sounds like they are worn out and slipping.
make sure thats where the noise is, the final drive or even the jack shafts on the wheels might be slipping or broken. noise in the trans has a tendency to travel so get a stethoscope for engines and see if you can pinpoint more where the noise is coming from.
Or...
you can just pull the trans and take it apart and see what the problem is.
either way that trans is probably coming out.
  • Posted 30 Dec 2023 09:19
  • Modified 30 Dec 2023 09:24 by poster
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
Still GX10
Still GX10 2000
Poland
EUR950
Terberg RT223
