Toyota 7FGCU25:
Trans control valve
Any other Toyota techs ever encounter a defective or perforated oil strainer (Toyota part # 32804-23330-71) inside the transmission control valve?
One of our trucks was pushed to the shop with a complaint of "Transmission does not work".
Trans would not operate in Forward or Reverse and pressure checks showed 165 PSI at the Main but 0 PSI at the clutch port.
Air pressure to the clutch ports with valve body removed showed clutches to be intact.
Tear down of the valve body revealed a stuck safety valve (Toyota part 32732-23330-71) and a stuck change valve (32735-23330-71). Both were bound up by debris and showed slight scratching. When I separated the valve body sections I discovered a 5mm sized section of the oil strainer missing completely.
I am just wondering if anybody else has ever found one of these strainers to be defective. I can't see any reason for this to happen unless it just vibrates and shakes a hole in the mesh or if it happens because of hydraulic "flow hammering" pulses.
Comments requested.
  • Posted 6 Jul 2012 03:40
  • Discussion started by L1ftmech
  • Tennessee, United States
Did I drop this posting in the wrong place or is what I found simply the first time it has ever happened?
At any rate the unit has been returned to service (with a new strainer and scratches polished out of spools) and is functioning normally again.
  • Posted 15 Jul 2012 03:05
  • Reply by L1ftmech
Louisville, KY, United States
Dubuque, IA, United States
