toyota 7fgu(15?)
I Have a toyota 7 series that will not stay running. as soon as you release the key it dies.... if you hold the key in and unplug the starter coil, the truck will appear to idle just fine. I Have checked the "usual" distributor connector has 12 volts to it. the single wire oil switch (by the fuse box) has 12v to ground. I swapped as many relays, between this truck and another just like it.
Oh Yeah, This truck died right after a " tune up" plugs/wire/cap/rotor etc.... HELP!!!
  • Posted 25 Nov 2008 07:58
  • Discussion started by NoBody
  • Virginia, United States
A true friend knows what it is!
I have had that key switch melt Rich
  • Posted 26 Nov 2008 07:23
  • Reply by rich_k
It sounds like the key switch is no good and is probably just a coincidence that it was just tuned up.
  • Posted 26 Nov 2008 00:28
  • Reply by duodeluxe
  • United States
duodeluxe
Taylor TE650S
Toyota 02-8FD25
Hangcha CPYD32XW71F-C
Flesherton, Ontario, Canada
Toyota 5FD60
UN Forklift FD40T
Unicarriers FD80-2
Louisville, KY, United States
Dubuque, IA, United States
