Toyota 42-6FGU25 Transmission pump pressure
Have a unit that when cold, will travel fine. Once fluid gets hot, barely moves. What is the M and C port pressure readings. Also could this be the torque converter. I recently change trans fluid and spin off filter, could this have anything to do with this? Thanks in advance!!
  • Posted 1 Dec 2012 02:06
  • By 1sharpdog
  • joined 20 Apr'12 - 220 messages
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
Kevin, thank you so much for your help. Isolated cause to micro filter clogged.
  • Posted 1 Dec 2012 04:06
  • By 1sharpdog
David Sharp
This have a one speed or two speed transmission? What fluid did you fill Trans with,it calls for dexron II.
1speed Trans:
M is Main PSI should be28-64 PSI at idle and 135-128 at 2000 RPM
C is Clutch PSI Should be 28-64 at idle and 128-178 at 2000 RPM,should also drop to zero when inching pedal is pressed
Torque Converter is also a 1/8 NPT close to the M port,it should be 30-90 PSI at 2000 RPM
2 Speed Trans:
M 71-142 at idle. 135-199 at 2000 RPM
C 64-121 at idle. 135-199 at 2000 RPM and drop when inching pedal pressed
Torque converter 30-90 at 2000 RPM
  • Posted 1 Dec 2012 02:42
  • By kevin_t
edition #1239 - 17 July 2025
As part of Forkliftaction’s 25th anniversary celebrations, we have dug into the archive and, over the next year, will be highlighting a carefully curated selection of historical stories we have published over this time... Continue reading
The origin of "love" as the score zero in tennis is debated, but two main theories prevail. One suggests it's derived from the French word "l'oeuf" (egg) which resembles the shape of the number zero. The other proposes it's related to the Dutch word "lof" meaning "honour" as players might be playing for honour when scoreless.
