Total weight for NRR40
I am thinking of getting a trailer to move our NRR40 but I can't find it's total weight anywhere in the manual or on internet. It's battery weighs 2000 lbs. Does anyone know what it's total weight is?
  • Posted 24 Nov 2021 13:47
  • By vsaks
  • joined 3 Sep'17 - 8 messages
Thanks so much Swoop. You are the forklift god.
  • Posted 20 Dec 2021 02:29
  • By vsaks
the Cat NRR40 weight is approximately 3600lbs roughly (without the battery).
So if your battery is 2k lbs then your total truck weight with the battery would be 5600lbs roughly.
I hope your using a low boy trailer, a standard trailer will make the OAH too high. Max height for any vehicle is 14ft i believe.
Just FYI, usually when these units are hauled they are laid down, the hyd tank breather is sealed off, drive unit breather capped so no fluid will leak out on the ground. You can haul it upright but like i said, height is the key factor so usually a lowboy trailer is used.
  • Posted 25 Nov 2021 17:59
UN Forklift FD50T-NJB3
Taylor TT300
USD98,500
