Hello, Having a travel problem with a 2011 RX60-40, Vin # 516327B00036. When trying to accelerate from a stop the truck shutters just a little, jumps and travel shuts down. Shows a code A28, 13. It does this in forward and reverse. I can get it to travel very slow if I don''t go past 3/4 throttle. Single pedal for travel.
Thanks for any assistance.
Hello! I am getting same error. Did you find the problem?
Can someone help me on this error code?
linde and still be sisters together
software but they are certainly not the same
Thank you Michel. I found that out when I tried to look up a part # for a throttle potentiometer. Can you tell me if this is the same troubleshooting procedure. Am I correct in troubleshooting the throttle.
dis truck is no linde truck But one still
Thank you tonason2 for your help,
That was my first thought. My guess it an open at the end of the throttle pot sweep. I was hoping to get a code description so I could make sure I am checking for an input or output problem. I try not to hang parts on to troubleshoot.
Check sensor engine speed driving.
