Error code D-75
Hi there, does someone know what is D-75 troubl6 means ?
My unit mode # DP50CN1 S/N AT19E80073.
It's working good, and some time the accelerator pedal inoperative, the RPM won't go up at all, then I turn off and turn engine on again to reset. Can someone help me please ?
  • Posted 12 Aug 2016 04:43
  • By mynor
  • joined 21 Apr'16 - 6 messages
mynor silva
I know the OP posted this a long time ago, but with the recent bump, here goes...
D-75 on these perkins dp50s is usually related to the idle validation switch not switching at the correct time relative to the throttle position ramping up.
I've found its usually either a bad idle validation switch, shorted wiring leading to it, or just mis-adjusted.
The pedal sensor voltage should be about.35vdc at minimum thither and the idle validation switch should be closedat this point, but open with any throttle input. It can take a few tries to find the sweet spot if you don't have the perkins software to view it while adjusting.
  • Posted 26 Nov 2024 10:01
  • By IdahoTech
  • joined 26 Nov'24 - 2 messages
  • Idaho, United States
I have been looking at this for a long time, and no one seem to find anything to fix this error code. I have your same model forklift and i am going to change the throttle position sensor. I think is that. I will advise. In the mid time, have you found anything on it?
  • Posted 28 Sep 2024 22:17
  • By Jdel
  • joined 28 Sep'24 - 2 messages
JD
Did you ever get a response to your question or did you figure out what the problem was? I have the same code and symptoms.
  • Posted 14 Mar 2017 05:49
  • By tyrone_m
  • joined 14 Mar'17 - 1 message
Helloooooooo,,, some body there ???
  • Posted 9 Dec 2016 09:06
  • By mynor
mynor silva
