Transmission pressure
I have this 7FGCU25 Toyota here in the shop, the clutch drums were spun, I replaced both drums, new seals, clutches, and pump, I cant get the trans pressure higher than 50psi, therefore its slow to shift, any prior experience??
  • Posted 3 Jun 2016 01:01
  • By lifrmybrednbut
  • joined 3 Jun'16 - 2 messages
lift things up and put them down
Did you take the valve body apart? Had a similar problem and it ended up being a regulating spring problem in valve body, also are you making sure the inching valve is closed all the way
  • Posted 3 Jun 2016 12:49
  • By fixnproblems
  • joined 19 Jan'13 - 66 messages
Toyota 3FD100
Elwell-Parker ESI500-36
