fault code 33029
displays an error VSM to Pump 33029
  • Posted 29 Apr 2016 01:48
  • Modified 29 Apr 2016 01:49 by poster
  • By sebek_c
  • joined 29 Apr'16 - 3 messages
  • gliwice, Poland
A internal fault in the controller could cause this code also.
  • Posted 30 Apr 2016 03:45
  • By BREWSKI
Thank you for your answer. The driver of the pump has been repaired. Is this an error that only about CAN line of controllers or controllers?
  • Posted 30 Apr 2016 02:24
  • By sebek_c
  • gliwice, Poland
This code indicates a loss of communication between the system manager and the pump controller through the canbus. check your connectors at the VSM and the hydraulic controller. The wires you need to check are the green/ yellow twisted pair. There could be a failure in one of the controllers also. If you are not familiar with checking the canbus loop in the truck you will probably need to get a copy of the diagnostic manual.
  • Posted 29 Apr 2016 22:35
  • By BREWSKI
Noblelift
