once again
Could anybody tell me, what are electrical parameters for transistors TSM002 , TSM001 (manuf.Toyoda) used in power
blocks to supply motors -driver and pump? Trucklift Toyota FBM16.
I've been trying to find it out for ages.
I need to know Vce, Ic, P. At least Ic should be enough for me. Thanks
  • Posted 3 Mar 2008 23:53
  • By vavco
  • joined 3 Feb'08 - 15 messages
  • Sabinov, Slovakia
Hi Terence,I have not found anything, seems it is almost impossible to find it out.However , I did not need it finally, you have to search some problem around them (transistors).Write me an e-mail, we can discuss about it if you want to.
  • Posted 4 May 2009 16:38
  • By vavco
  • Sabinov, Slovakia
e-mail: vladovavrek@gmail.com
Hi Vavco. It has been over a year since you posted requesting info about TSM002 and TSM001. Did you find any data about the transistors and diodes? I have a 5FB18 which has the same kind of trouble, works for a few seconds ok, then burns out the main drive transistor. Thank you.
  • Posted 2 May 2009 23:07
  • By terence_d
  • joined 2 May'09 - 1 message
  • N/A, Malta
Toyota 8FD45
JCB 533-105
Combilift Ltd
