Idles somewhat rought
92047 is the serial number. Has an H20 motor.
This unit will idle ok, not quite what it should. When you hit the throttle, it opens up to about 1700 RPMS, and quickly falls back down to 0, cuts the lift off. While running, and when I go to hit the throttle, I spray a aerosol lubricant around the intake gasket mounting and the engine will maintain 1700 RPMS as long as there is a spray. I am going to install an intake gasket. Has anyone else run across this?
  • Posted 26 Jan 2016 17:12
  • By Hero5
  • joined 17 May'14 - 56 messages
Take care of the customer
Well I found the problem. After going through the engine vacuum system, it ended up being a restricted muffler
  • Posted 29 Jan 2016 12:01
  • By Hero5
worn out govenor
  • Posted 27 Jan 2016 14:13
  • By fixnproblems
  • joined 19 Jan'13 - 66 messages
seems common check the manifold for cracks as well
  • Posted 26 Jan 2016 21:58
  • By Adams1
  • joined 24 Jun'15 - 61 messages
  • Indiana, United States
SMV (Konecranes) 12-1200B
Terberg YT220
Muncie, IN, United States
Terberg YT220
Terberg YT220
