Toyota 7FBEU15 Hydraulic problem
Hey guys, I'm having an issue with a Toyota 7FBEU15. I have no hydraulic functions. I have steering but no functions. I don't have any codes and the truck travels fine. The motor runs and the pump is working. Any ideas? I have tried to adjust the pressure relief valve on the manifold but it does'nt make a difference. One thing that I see on the display that I don't believe has anything to do with it is
! TO OPERATING POSITION !
this does go away when the seat switch is depressed. Any help or ideas would be appreciated.
  • Posted 17 Jul 2015 02:57
  • Modified 17 Jul 2015 04:19 by poster
  • By Warren
  • joined 17 Jul'15 - 3 messages
  • Alabama, United States
Yes it seems like the pump just jitters a bit when you move any lever.
  • Posted 4 Jan 2025 17:21
  • By Alex_Gonzalez
  • joined 4 Jan'25 - 2 messages
Alex G
Did you ever find a solution to this problem? Unit i have is doing same thing, just jitters a little bit when you move the levers or any hydraulic functions?
  • Posted 4 Jan 2025 17:20
  • By Alex_Gonzalez
Alex G
HI , CHECK IN DASHBORD MENU INPUT OF JOYSTICK LEVERS.
  • Posted 22 Jul 2015 01:10
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Hi Warren,
Does the pump motor start to run when you activate one of the hydraulic levers?
  • Posted 20 Jul 2015 19:53
  • By luke_k
  • joined 20 Jul'15 - 7 messages
  • Queensland, Australia
Enforcer FLBAXT25
SMV (Konecranes) SL37-1200A
