fault code 177-4
We have a yale glp080vxngae086 serial number j813v01572l. It started throwong the code 177-4 thos morning. The unit is running fine and have physically checked over the unit. Any help on what the code is would be appreciated.
  • Posted 18 Apr 2015 02:01
  • By Davies
  • joined 18 Apr'15 - 17 messages
Checked out the sensor, apparently the wires were exposed right at the connector. repaired the connection and haven't had an issue since. Thanks for the help!
  • Posted 23 Apr 2015 12:37
  • By Davies
Better to troubleshoot the sensor then just chnage parts IMO.
But yes, it would be due for a trans service.
Be sure that the trans case breather is clean as well.
  • Posted 20 Apr 2015 20:06
  • By Robe
  • joined 6 Mar'13 - 105 messages
  • Nova Scotia, Canada
Just noticed the unit has just under 2000 hours since last trans service. You thinkit might just need a service or change out the sensor?
  • Posted 18 Apr 2015 04:59
  • By Davies
check transmission temp sensor.
  • Posted 18 Apr 2015 03:36
  • By kevin_k
Michel Denis Michel Denis
