Error code E1925
Hi, I have a Jungheinrich EJE 116 with an error code- E 1925.
Any ideas?
I have replace the tiller control, not sure if it needs calibrating.
Regards
Dan
  • Posted 10 Mar 2015 19:19
  • Modified 10 Mar 2015 20:07 by poster
  • By Dan81
  • joined 6 Feb'13 - 45 messages
  • Kent, United Kingdom
HI, Thanks I will check it out.
Very helpful much appreciated.
Cheers
  • Posted 11 Mar 2015 06:07
  • By Dan81
This error relates to the shunting switch or anti crush switch as I call it. The truck sees the switch as closed during star up. It could be that you accidentally jammed the switch in the on position when installing the card. If this is ok, check wiring connections and the switch in case it is a faulty unit. If you have Judit you can connect and see if the switch is open or closed
  • Posted 11 Mar 2015 05:47
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
Crown WP302020
Toyota 8FG25
Lift Tek Elecar
Crown WP302020
Toyota 8FG25
