Free lift cylinder not moving
The hydraulics on my free lift cylinder are acting goofy. The free lift does not go up, instead the outer stages go up. When I took the cylinder apart there seemed to be a vacuum on the bottom of the cylinder, so I had to release the pressure by taking off the hydraulic lines to take it apart. I cleaned everything up put it back together and it worked fine for a little while, but went back to doing the same thing. I am stumped, any help would be appreciated.
  • Posted 22 Feb 2015 06:05
  • By roy_m
  • joined 22 Feb'15 - 2 messages
  • Indiana, United States
You need to check the poppet valve in the bottom of the free lift cylinder ram. It sounds like the valve is blocked or came apart.
  • Posted 27 Feb 2015 00:47
  • By BREWSKI
Roy,
I think I would check the main relief valve as I think it may need resetting as the tilt and aux system is operated through the secondary relief valve.
Nero.
  • Posted 24 Feb 2015 09:21
  • By NER045
SMV (Konecranes) 4632CC5
Linde C4230TL5
F. Uchiyama
F. Uchiyama
Michel Denis Michel Denis
