7400 FA lift works at the same time when aux triggered
Hi folks,
Badly need your help I'm working a raymond 7400 FA model,the problem was when I triggered the aux function the lift cyl works at the same time I already replaced the control handle and sealed the POD-1(solenoid). Do you have some idea to solve this issue.? The truck throw code81 an 83 intermittent.
Thanks in advance for your help and God bless us all.
  • Posted 9 Jan 2015 00:40
  • By forkliftcity
  • joined 23 Jul'10 - 52 messages
  • cebu, Philippines
don't bite the hands that feed you!
Hi Raytech,
Thanks for your reply. I already fix the issue I just replace the PODS with a new one and re-learn the control handle.
Thank you and God bless us all
  • Posted 16 Jan 2015 18:54
  • By forkliftcity
  • cebu, Philippines
Sol 3 needs replacement.
Open motor door, its on Hyd manifold, facing you on top. Yoy can remove with a wrench from top if you dont have the correct socket.
Very common
81 and 83...lift pot codes...you did re-learn the new handle correct?
  • Posted 11 Jan 2015 02:08
  • Modified 11 Jan 2015 02:35 by poster
  • By EasiTek
Can you post full model and serial number. Thanks.
  • Posted 9 Jan 2015 09:34
  • By TTLLOGIC
  • joined 25 Dec'14 - 15 messages
Esie Cortez Esie Cortez
UN Forklift FB25N1LZ1
