Retract
Hello
Having an issue with hydraulics on a doube reach. When the operator has the mast extended with a heavy load, it won't retract correctly. It will side shift one way completely and then it will do what is requested. Being as this has 5 hydraulic valves, can I get any ideas?
  • Posted 30 Dec 2014 11:33
  • By Hero5
  • joined 17 May'14 - 56 messages
Take care of the customer
This is coming in very late, have you located and disassembled the diverter valve?
This valve is known to stick/ not open or close at the appropriate time.
  • Posted 3 Jul 2015 04:55
  • By LaGrange
  • Missouri, United States
I would check the solenoids for a sticking one...either in the tilt or the side shift proportional control valve
  • Posted 30 Dec 2014 13:22
  • By kevin_t
It's erratic at best when lowered. Their is a display on this unit that when you retract, extend, etc it displays what action you are doing. Sometimes when you request tilt down it will side shift completely right first then it willl tilt down. But all the while it will be displaying tilt down. I think it is a hydraulic issue an not a control issue but definitely am here to get all the input I can
  • Posted 30 Dec 2014 13:10
  • By Hero5
One question to ask,does it act normally when it is in the lowered position?
  • Posted 30 Dec 2014 13:01
  • By kevin_t
Sounds like there is a soleniod spool sticking in the proportional control....another possibliity is a switch issue in the cntrol handle.....check your solenoids for a sticking one.....and chck for a sticking or malfunctioning control handle
  • Posted 30 Dec 2014 13:00
  • By kevin_t
N30xmdr3
G138n01646z
  • Posted 30 Dec 2014 12:28
  • By Hero5
Full model and Serial number of truck???
  • Posted 30 Dec 2014 11:37
  • By kevin_t
UN Forklift FD30-35T
SMV (Konecranes) 33-1200C
Deborah Baker Deborah Baker
