Hydraulic interlock Return to neutral
Hello,
This time i'm working on a another forklift Hyster 3.0 FT ( L177B33159J)
The DSC displayed the following message " Hydraulic interlock return to neutral".
With the DSC i have check the seat sensor. He is over 1.5 volt ( actually, 3.40 volt) so he is good.
Then i check the mini lever, always with the DSC. ( I also change it to be sure..) He is good too.
Any fault codes appears.
Could someone give me more information?
Best regards
Paul.
  • Posted 30 Jul 2014 06:57
  • By PaulfromTahiti
  • joined 22 Jul'14 - 19 messages
  • Tahiti, French Polynesia
Hello BREWSKI,
pls can you send me calibration procedure manual also? i sure need it, i have the same problem ( hyd. interlock return to neutral)
Thanks vm.
  • Posted 29 Oct 2020 07:28
  • By VZVTECH
  • joined 29 Oct'20 - 1 message
  • Slovakia
Sounds like it needs the CDF flashed. This requires a laptop with the proper software and access to the CDF file. The CDF is only available to authorized dealers.
  • Posted 17 Aug 2016 22:33
  • By BREWSKI
I Have Another Machine, I Remove mini-lever and Replace it with Breakdown machine, Display show ( 30 second to shutdown) after 30 second nothing show on display.
I return back old mini lever, machine now showing only on display 30 sec. to shutdown & after 30 sec. nothing show even not crank the engine.
  • Posted 17 Aug 2016 17:25
  • By KASBATIOUN
  • joined 3 Jun'15 - 12 messages
  • lagos, Nigeria
If it shows calibration out of range you need to replace the minilever.
  • Posted 16 Aug 2016 22:49
  • By BREWSKI
Hello, I have Same Problem, I'm Trying To Calibrate but always Showing on Display Calibration out of range
please can you help
  • Posted 16 Aug 2016 17:54
  • By KASBATIOUN
  • lagos, Nigeria
Hello,
You have to calibrate the mini lever with the display.
Use the key "*" to select "enter password" in the menu with the arrows keys. The password is 55555. Then, go in the "calibrations" section and start the procedure you want to calibrate.
  • Posted 22 Oct 2014 06:08
  • By PaulfromTahiti
I am having the same issues and I dont know the procedure to calibrate them, any help is appritiated
  • Posted 17 Oct 2014 01:25
  • By PacificAqua
  • joined 17 Sep'14 - 4 messages
  • Washington, United States
Problem solved!!
It came from the mini levers. One of them was Out of range and the neutral position was not detected. After the calibration procedures, the message disappear.
  • Posted 30 Jul 2014 08:04
  • By PaulfromTahiti
