Access 3 Issue
I'm having trouble with my Crown RR 5000 Reach. When I start the truck up it begins the self test and stops/stays frozen displaying "Test". I can't access anything and the truck is completely nonoperational. The Orange light on the Access 3 blinks twice every few seconds. No other codes.
Please help. Thanks.
  • Posted 22 Feb 2014 03:32
  • By Leatherface96
  • joined 22 Feb'14 - 2 messages
  • Illinois, United States
Hi leatherface96
I have same problem with you, I was repair and fix now. TEst will appear cause system fail communication between akses 1,2,3
system must be communication before ( self test ) and make sure all fuction done and unit ready for use
Fail communication due to about line on mainboard broken , electronic component ( demage or fatique ) and program on IC lost
to make sure repalece broken akses3 and put on other unit, copy setup first.
perhaps my opinion can help you
  • Posted 24 Jun 2014 21:32
  • By fafan
  • joined 24 Jun'14 - 2 messages
  • jawatimur, Indonesia
I wound up figuring the problem out before I received any replies.
Simply put: Your Access 3 is bad and needs to be replaced. After I replaced mine and used the copied setups for the Access 3 module the truck was working perfectly.
  • Posted 16 Apr 2014 01:10
  • By Leatherface96
hello, i also have a Crown RR5220-45 serial # 1A25794 that is showing "TEST" after it goes thru the self test. no travel, no lift. did you get a reply to this issue?
thanks,
Jay
  • Posted 9 Apr 2014 07:50
  • By glenn_levit7
  • joined 10 Jul'07 - 78 messages
Montacargas, Tequila y Limon!
What is the model year of your access 3?
  • Posted 6 Apr 2014 06:12
  • By jcasass
  • joined 6 Apr'14 - 1 message
  • Select Your State or Province, Colombia
Javier Casas Salgado
MAXAM Tire, Inc.
MAXAM Tire, Inc.
