Differential
my daewoo with auto transmission, the ATF pops out when you
apply brakes, thanks
  • Posted 2 Oct 2007 23:02
  • By chrisgst
  • joined 2 Oct'07 - 1 message
  • mm, Philippines
Sorry,but i have to disagree with your answer.Please check that you are not using "regular 10w hydraulic" oil in the transmission.Because if you are you are using the wrong oil.You will have transmission and brake problems if you do.
The oil you need contains anti glazing chemicals,clutch packs and brake discs will fail (in OCDB).There is a Q8 equivalent that we use,i will get the details if required.
  • Posted 11 Jul 2008 07:35
  • By alan_m
  • joined 20 Apr'07 - 72 messages
  • United Kingdom
first daewoo dont use atf oil the red color is just an ink they use so u know if the truck have had its first service crucial on the transmission it takes a regular 10 w hydraulic , if is hydraulic powered brakes u might have a leak from the main pump front of transmisssion or seal in the hydraulic booster
  • Posted 10 Jul 2008 08:30
  • By rodrigo_e
  • joined 10 Jul'08 - 5 messages
  • Ireland, Ireland
It is possible that faulty brake seals are causing the oil to fill drive axle.
  • Posted 25 Oct 2007 19:19
  • Modified 11 Jul 2008 07:37 by poster
  • By alan_m
  • United Kingdom
The transmission is pushing (ATF)Automatic Transmission Fluid out of the dipstick tube?
  • Posted 3 Oct 2007 10:00
  • By Truck_Tech
  • United States
Oxford Ct, United States
UN Forklift FD40T
Toyota 02-8FD25
Esie Cortez Esie Cortez
